Mailbutler Dashboard & Settings
Last updated on 23 Sept, 2025
How do I access my account settings and preferences?
After downloading and installing Mailbutler, you can customize our features to suit your needs in your Mailbutler preferences.
How do I select my privacy settings?
Privacy settings in your Dashboard allow you to control how much information Mailbutler stores about your emails.
How do I manage my Mailbutler subscription?
You can easily manage your Mailbutler subscription from right inside your inbox.
Where can I find my subscription invoices?
You can easily view and download all your subscription invoices.
How do I update my Mailbutler billing information?
You can update your billing information at any time, in your Mailbutler Preferences.
How do I exclude IP addresses from Tracking?
You have the option of blocking specific IP addresses from being tracked, so that you aren't notified when a coworker opens your emails, for instance.
How can I change the language of Mailbutler?
Mailbutler is currently available in the following languages: English, German, Spanish and French, so don't hesitate to change the language of Mailbutler into your favourite one.
What is the early access program and how can I join it?
This article provides you with information on what the early access program is as well as instructions on how to join it.
How do I pin Mailbutler in Outlook?
This article describes how you can pin the Mailbutler button as well as the Mailbutler Sidebar in Outlook, so that Mailbutler is always there, easy for you to access.
How does Mailbutler's Referral Program work?
Want to save on your Mailbutler subscription? Join our Referral Program and earn discounts every time you refer someone!
