How do I import contacts from a CSV file?
Import contact information from a CSV file to personalize emails with Mail Merge.
Last updated on 07 Aug, 2026
You can import a CSV file containing recipient information, such as email addresses, names, and company details. Mailbutler uses this information to fill the corresponding placeholders in your Message Template when you send emails with Mail Merge.
  1. Open a new email draft.
  2. Open the Mailbutler Sidebar.
  3. Make sure the Draft view is selected.
  4. Click Import from CSV.
  1. Select the CSV file you want to import.
The imported email addresses automatically appear in the To field. Mailbutler uses additional contact information from the CSV file, such as names or company details, to fill the corresponding placeholders in your Message Template.
Mailbutler Dashboard & Settings
