Mailbutler Dashboard & Settings
How do I pin Mailbutler in Outlook?
This article describes how you can pin the Mailbutler button as well as the Mailbutler Sidebar in Outlook, so that Mailbutler is always there, easy for you to access.
Last updated on 25 Jul, 2026
How do I pin the Mailbutler button in Outlook?
You can pin the Mailbutler button which opens the Mailbutler Sidebar, so that you can always quickly access it.
Outlook app (Mac)
You can pin the Mailbutler button to both your inbox and your compose window.
To pin the Mailbutler button to your inbox, follow the below steps.
1. Open your Outlook inbox.
2. Click on the three dots in your Outlook toolbar.
3. Click Customise Toolbar...
4. Drag and drop the Mailbutler button into your Outlook toolbar. Place the Mailbutler button on the left of the toolbar, so it does not get hidden when your Outlook window is minimized.
5. Click Done.
6. The Mailbutler button is now pinned to your inbox.To pin the Mailbutler button to your compose window, follow the below steps.
1. Start a draft.
2. Click on the three dots in your Outlook toolbar.3. Click Customise Toolbar...
4. Drag and drop the Show Sidebar button into your Outlook toolbar. Place the Show Sidebar button on the left of the toolbar, so it does not get hidden when your Outlook window is minimized.
5. Click Done.
6. The Mailbutler button is now pinned to your compose window.
Outlook app (Windows)/Outlook.Office.com
1. Open your Outlook inbox and go to any email or start a new email.
2. Click the Apps button.
3. Right-click the Mailbutler icon and click Pin.
4. The Mailbutler button is now pinned to your inbox and compose window.
How do I pin the Tailored Send button in Outlook?
Pin the Mailbutler Tailored Send button for easier access. Tailored Send ensures that each recipient receives an individual, personalized copy of your email when sending to multiple recipients.
Outlook app (Mac)
1. Open your Outlook compose window.
4. Drag and drop the Tailored Send button into your Outlook toolbar. Place the Tailored Send button on the left of the toolbar, so it does not get hidden when your Outlook window is minimized.5. Click Done.
6. The Tailored Send button is now pinned to your compose window.
You cannot pin the Tailored Send button directly to your compose toolbar in Outlook app (Windows)/Outlook.Office.com.
However, you can pin the Mailbutler button to your toolbar instead. This gives you quick access to both the Tailored Send option and the Mailbutler Sidebar. To do this, follow the steps outlined here.
Once pinned, simply open the Mailbutler button from your toolbar to access the Tailored Send feature.
How do I pin the Mailbutler Sidebar in Outlook?
You can pin the Mailbutler Sidebar, so it is always there when you switch between emails and folders and you don't need to open it manually each time.
Outlook app (Mac)
1. Open Outlook and go to an existing email and/or compose a new email.
2. Open the Mailbutler Sidebar.
3. Click on the pin icon.
Your Mailbutler Sidebar is now pinned and will stay opened when you switch between emails and folders.
How does Mailbutler's Referral Program work?
