Get Started
Learn the basics and get up and running quickly.
Last updated on 06 Aug, 2026
Articles
How do I register and install Mailbutler?
Follow these easy steps to get started with Mailbutler and begin enjoying the benefits of all our features.
How do I log in to Mailbutler?
The Mailbutler login option is located directly in your email client.
How do I access the Mailbutler navigation bar?
Everything around your emails, notes, tasks and activities is located directly inside your Mailbutler sidebar. Learn how to access all the information that you need to manage your emails!
How do I subscribe to a Mailbutler plan?
We've made it easy for you to manage your subscription.
How do I add and manage team subscriptions?
Purchase multiple subscriptions under one account and distribute them to your colleagues. This allows you to manage your team's subscriptions from one centralized place.
How do I use the Mailbutler Mobile App?
Enjoy Mailbutler's features from the convenience of your own phone or tablet!
How do I authorize Mailbutler for my email account in Apple Mail?
This article provides a detailed guide on correctly authorizing various types of email accounts in Apple Mail.
How do I attach the Mailbutler Sidebar to the Apple Mail window?
You can easily attach the floating Mailbutler Sidebar to the Apple Mail window. Here is how!
How do I open/close the Mailbutler Sidebar?
Here is how you can open and close your Mailbutler Sidebar.
How do I use the Mailbutler Sidebar side by side with Mail in full screen mode?
If you are using Mail in full screen mode, follow these instructions to place the Mailbutler Sidebar side by side your Mail window, rather than it covering the Mail window.
How do I connect my Contacts Manager or CRM Tool to Mailbutler to send personalized emails?
Mailbutler allows you to connect your Apple/Google/Outlook Contacts, your CRM tool as well as contacts from a CSV file to Mailbutler. This contact data is then fetched to personalize your emails when sending with Message Templates.
How do I view Mailbutler's tracking insights in my CRM tool?
Connect Mailbutler to your CRM tool to display Mailbutler’s email tracking data right inside your CRM tool.
