Please select the software you are using for your emails.
If you want to manage your Message Templates in your Dashboard, click here.
You can create a Message Template from an existing email or when you are composing a new email. You can create a Message Template from the email text, header, subject or image.
1. Go to Apple Mail and select the email you want to create a Message Template from.
2. Mark the text or image that you want to include in your Message Template and right-click it.
3. Click on New Message Template from…
4. A new Message Template will be created. Go to the Dashboard to edit the Message Template and insert Placeholders.
1. Go to Gmail and select the email you want to create a Message Template from.
Dashboard
1 . Login to your Mailbutler Dashboard.
2. From your sidebar menu, go to Message Templates.
3. Click on New Template.
4. Name your template and enter the Subject of your message. Click on the Editor icon to open the rich text editor.
5. Enter your message body in the rich text editor. You can customize your formatting, colors; add links, images, tables, and placeholders.
Note: If you have enabled Link Tracking, links included in your message templates (including images) will automatically be tracked.
6. For team users: select the team you want to share this template with under Team Sharing. (More about Shared Message Templates)
7. Click Update.
Message Templates created on your Dashboard are automatically synced to Mailbutler in your email client.
Learn how to insert a Message Template in your email.
Manage your Message Templates in your Dashboard
You can find a collection of all your created and shared Message Templates in Dashboard -> Message Templates.
This page shows you:
- The sharing status and owner of a shared template
- The number of times a template was used
- The open rate of a template (requires Open Tracking)
- The click through rate
- The reply rate
Additionally, here you can make the following changes to your Message Templates:
- Duplicate the template
- Edit and make changes to the template, including revoke team access
- Delete your template (you cannot reverse this)
Share Message Templates with your team
Message Templates created in Mailbutler can be shared with members of your team.
Learn more about Shared Message Templates.
(What’s Mailbutler for Teams?)
