💡 Good to know: Mailbutler integrations automatically keep your data in sync. Some integrations support two-way synchronization, while others only sync data from Mailbutler.
Step 1: Open Mailbutler
Open the Mailbutler Sidebar:
👉 Gmail
👉 Outlook
Step 2: Open integrations
Go to Account & Preferences → Integrations.
Step 3: Connect a service
Click the + button and select the service you'd like to connect.
Step 4: Choose a sync destination
Once the service is connected, select where you'd like Mailbutler to sync your data, such as a project, notebook, list, or folder.
