How do I set up a Custom Tracking Subdomain?
Set up your own tracking subdomain to increase trustworthiness of your tracked emails and reduce the risk of spam filters blocking them.
Last updated on 04 Feb, 2026
When you send emails with Mailbutler's Tracking and/or Link Tracking feature, we add a link to your emails, which contains "mlbtlr.com" to be able to detect whether your emails have been opened/your links have been clicked.
To increase the trustworthiness of your tracked emails and to reduce the risk of spam filters blocking your emails, you can configure your own tracking subdomain to replace "mlbtlr.com".
Please only follow the instructions in this article if you understand the concept of subdomains.
Please note: Among Mailbutler Collaborators, a custom tracking subdomain needs to be configured only once. All collaborators can then set up the same subdomain.
Please note: To be able to set up a Custom Tracking Subdomain, your domain needs to be configured to explicitly allow Amazon domains to issue SSL certificates.
This can be configured in CAA records in your DNS configuration.
For more information, please head to this page:  https://docs.aws.amazon.com/acm/latest/userguide/setup.html#setup-caa
1. Open the Mailbutler sidebar in your email client.
2. In the Mailbutler Sidebar, click the three dots and then Account & Preferences.
3. A new window will open. Select General under Preferences in the sidebar on the left.
4. Enter your preferred subdomain, for example: t.company.com, and press Enter.5. Verify the ownership of the domain by setting CNAME ... to ... Once you have done that, click Verify status.6. Redirect your domain by setting CNAME ... to ... Once you have done that, click Verify status.
7. If you see below success message, your custom tracking subdomain has been successfully set up.
How do I use Mail Merge?
