How do I filter information inside the Mailbutler navigation bar tabs?
You can quickly find the relevant information inside the navigation bar by using filters.
Last updated on 02 Jun, 2026
1. Click on the sidebar icon to open the Mailbutler Sidebar.
2. Select a tab.
3. Click on the Filters button.
4. Select the filters that you want to apply and click Apply.
1. Click on the Mailbutler icon to open the Mailbutler Sidebar.
2. Select a tab.
1. Open the Mailbutler Sidebar.
2. Select a tab.
Mobile App
1. Open the Mailbutler Mobile App.
2. Select a tab.
3. Click on the Filters button.4. Select the filters that you want to apply and click Filter.
How do I schedule an email with Smart Send Later?
