Where can I see the tracking checkmarks on macOS Sonoma and higher?
You can still see the tracking checkmarks on macOS Sonoma and higher - they are just in a different place now!
Last updated on 02 Jun, 2026
1. Go to your sent folder.
2. Select the email that you would like to check the tracking status for.
3. You will see the tracking checkmarks in the top left corner of your email.4. Hover over the checkmarks to see when your email was fist opened and/or your link first clicked.5. Click on the checkmarks to open Tracking Details for the email.6. You also have the option to check the tracking status of your emails in the Mailbutler Sidebar or under the Emails tab of the Mailbutler navigation bar. Head to this article to find out more.
For more information on what has changed in Mailbutler on macOS Sonoma and higher, check out this article.
How do I use Mailbutler's Shared Inbox Collaboration features?
