Please select the software you are using for your mails
If you just want to configure snooze settings in dashboard, please click here.
Snoozing in Apple Mail
1. Go to your inbox.
2. Select the email you want to snooze.
3. Locate the Snooze button.
4. Click on the drop-down arrow of the Snooze button to set the time and date you want the message to reappear in your inbox.
5. Your email is now in the Mailbutler – Snoozed folder.
6. If you click on the email, it will open on the right side of your mail window. There you can unsnooze it if you want to by clicking on the respective button.
7. Once you have unsnoozed an email, it will reappear in your inbox.
Compatibility Mode for Snooze on Apple Mail
If you fail to Snooze a message on Apple Mail, this may be due to an unsupported email server. Email accounts that are not fully compatible can use Snooze under Compatibility Mode. Please refer to this article on how.
Snoozing in Gmail
4. Set the time and date you want the email to reappear in your inbox.
5. The email is now in the Snoozed folder.
6. If you click on the email your message will open. In there you can unsnooze your email by clicking on Unsnooze.
7. Once you have unsnoozed an email, it will reappear at the top of your inbox.
Snoozing in Outlook
3. Click on the Snooze button next to the Mailbutler add-in.
4. The email will now be snoozed using the default snooze time interval from your Dashboard Preferences.
5. The message is now in the Mailbutler Snoozed folder.
Configure Snooze settings in Dashboard
You can change default settings of Snooze in your Preferences.
1. Open your Dashboard.
2 . From the drop-down menu of Account Settings, select Preferences.
3. Under the Working hours tab, locate the Snooze preferences:
- Snooze to working hours only – temporarily archive emails you want to deal with during your specific office hours.
4. Under General tab, you can change the snooze interval settings
- Snooze default time interval – set the default time frame for Mailbutler to temporarily snooze messages you want to deal with later. This will appear in your inbox as the default custom date when snoozing a message (see Apple Mail picture from step 4).
- Snooze time intervals – you will archive your emails according to the time frames you set here (check Apple Mail picture from step 4).
4. Changes are automatically Saved.
