How can I connect additional email accounts to Mailbutler?
FAQs
You can connect as many email accounts to Mailbutler as you want. Here is how.
Last updated on 18 Feb, 2026
Unlike most email software, we do not restrict the number of email accounts connected to your Mailbutler account. This means that you can connect an unlimited number of email addresses to a single Mailbutler account/subscription, provided that the email addresses are being used by a single user. Please refer to our Terms and Conditions for more information.
To use Mailbutler for additional email accounts in Apple Mail, you do NOT need to connect the additional email addresses manually. All you need to do is start using Mailbutler in the other account. Mailbutler will then ask for your permission to access the account.
Please note that you can connect an unlimited number of email addresses with a single Mailbutler account/subscription - provided that you are the only person using the email addresses.
To use Mailbutler for additional email accounts in Gmail, you do NOT need to connect the additional email addresses manually. All you need to do is start using Mailbutler in the other account. Mailbutler will then ask for your permission to access the account.
To use Mailbutler for additional email accounts in Outlook, you need to install Mailbutler for each of the accounts separately. To do that, download Mailbutler for each email account from this link: https://bowtie.mailbutler.io/downloads
What is Cloud Delivery?
