This feature can be extended in Mailbutler for Teams. You can share created items with your team members.
Please select the software you are using for your emails.
Learn how to create and manage Message Templates.
Message Templates in Apple Mail
You can either insert a Message Template before or after you have started composing a message on Apple Mail.
- To start an email with a Message Template, click on the drop-down menu button next to your compose button:
- To insert a Message Template after you began composing, click the Message Template button in your compose window:
Message Templates in Gmail
You can either insert a Message Template before or after you have started composing a message in Gmail.
Message Templates in Outlook
1. Open Outlook
2. Start composing a message
3. Open the Mailbutler add-in
4. Select the Message template you would like to use.
Message Templates on Mobile
1. To start writing an email click on the airplane icon at the bottom right of your screen.
2. To insert a Message Template, click the Message Template button: {+} in your compose window.
