🔔 Note: Uninstalling Mailbutler does not automatically delete your Mailbutler account or cancel your subscription.
1. Click the Mailbutler icon in your Mac menu bar.
2. Follow the on-screen instructions to uninstall Mailbutler.
Gmail (Chrome)
1. Open Google Chrome.
2. Click the Extensions icon.
3. Click the three dots next to Mailbutler for Gmail.
4. Select Remove from Chrome.
Outlook for macOS
Open Outlook.
Click the three dots in the toolbar.
Select Get Add-ins.
4. Open My Add-ins.
5. Locate Mailbutler, click the three dots, and select Remove.
Outlook for Windows
1. Open Outlook.
2. Click Apps.
3. Right-click Mailbutler and select Uninstall.
Outlook on the web
1. Open Outlook.
2. Click Apps.
